Ana içeriğe geç
Amazon Echo Motherboard Replacement
Neye ihtiyacın var
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: adım 1, 1 resimden 1.
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: adım 3, 1 resimden 1.
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: adım 5, 2 resimden 1. Amazon Echo Motherboard Replacement: adım 5, 2 resimden 2.
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 3.
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Amazon Echo Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: adım 8, 1 resimden 1.
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: adım 9, 2 resimden 1. Amazon Echo Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 3.
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard up from the Echo.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Alexander Albert
1.169 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G3
4 Üyeler
12 adet Kılavuz yazıldı
11Kılavuz Yorumları
Where can you get the mmotherboard
Glen Seay - Yanıt
same question. where do i get replacement motherboard?
akn978s - Yanıt
This is how to remove the motherboard not how to replace it....geez
adairt - Yanıt
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Yanıt
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 73
Her zaman: 15,715
