Ana içeriğe geç
Amazon Echo Motherboard Replacement
Neye ihtiyacın var
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: adım 1, 1 resimden 1.
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: adım 3, 1 resimden 1.
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - Yanıt
    Wo kann ich Ersatzteile holen für Amazon Echo
    Okka Mehmed - Yanıt
  5. Amazon Echo Motherboard Replacement: adım 5, 2 resimden 1. Amazon Echo Motherboard Replacement: adım 5, 2 resimden 2.
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    Were do you get the board?
    nick poverman - Yanıt
  6. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 6, 3 resimden 3.
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - Yanıt
    Me to, i need this board to my alexa echo
    benjaminaflorentino - Yanıt
    So anyone found out where we can get these boards and other components ?
    Jimmy - Yanıt
    I need this board to my echo 2nd, where can I find one?
    Pedro B - Yanıt
  7. Amazon Echo Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Amazon Echo Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
    These instructions are not going to help me because I am trying to repair an Alexa Echo Show.
    Tami Schaumburg - Yanıt
  8. Amazon Echo Motherboard Replacement: adım 8, 1 resimden 1.
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: adım 9, 2 resimden 1. Amazon Echo Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 1. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 2. Amazon Echo Motherboard Replacement: adım 10, 3 resimden 3.
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard up from the Echo.
    Without a source for replacement motherboards this guide is useless.
    Minok - Yanıt
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexander Albert
1.145 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G3
4 Üyeler
12 adet Kılavuz yazıldı
11Kılavuz Yorumları
Where can you get the mmotherboard
Glen Seay - Yanıt
same question. where do i get replacement motherboard?
akn978s - Yanıt
This is how to remove the motherboard not how to replace it....geez
adairt - Yanıt
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Yanıt
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Yanıt
Any luck with finding a replacement motherboard ?
Rebel Face - Yanıt
Where can i get the amazon echo plus motherboard ? any resellers
Shyam Sunder - Yanıt
Where can i get the amazon echo plus 1st generation motherboard
i am in need of the motherboard where do i get it please ?
Parts can be found on eBay guys.
Andrew K - Yanıt
No they cannot , I see zero listings for echo motherboards. If the part was produced here would be listings. Amazon produced just enough and shut production down. Manufacturer of ewaste is best I can classify amazon as given the electronic device just does after 5-7 Years of at most using electricity.
Minok -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 15,281
