Ana içeriğe geç
Amazon Echo Power and Speaker Driver Board Replacement
Neye ihtiyacın var
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: adım 1, 1 resimden 1.
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: adım 2, 3 resimden 1. Amazon Echo Power and Speaker Driver Board Replacement: adım 2, 3 resimden 2. Amazon Echo Power and Speaker Driver Board Replacement: adım 2, 3 resimden 3.
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: adım 3, 1 resimden 1.
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: adım 5, 2 resimden 1. Amazon Echo Power and Speaker Driver Board Replacement: adım 5, 2 resimden 2.
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: adım 6, 3 resimden 1. Amazon Echo Power and Speaker Driver Board Replacement: adım 6, 3 resimden 2. Amazon Echo Power and Speaker Driver Board Replacement: adım 6, 3 resimden 3.
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Alexander Albert
1.169 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G3
4 Üyeler
12 adet Kılavuz yazıldı
22Kılavuz Yorumları
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - Yanıt
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
same here...
D Nation - Yanıt
Where do I get a replacement board ?
Sean Burch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 25
Son 30 gün: 142
Her zaman: 28,410
