Ana içeriğe geç
Amazon Echo Show 15 Camera Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 15 Camera Replacement, Back Panel: adım 1, 3 resimden 1. Amazon Echo Show 15 Camera Replacement, Back Panel: adım 1, 3 resimden 2. Amazon Echo Show 15 Camera Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Echo Show 15 Camera Replacement: adım 2, 3 resimden 1. Amazon Echo Show 15 Camera Replacement: adım 2, 3 resimden 2. Amazon Echo Show 15 Camera Replacement: adım 2, 3 resimden 3.
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: adım 3, 3 resimden 1. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: adım 3, 3 resimden 2. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: adım 3, 3 resimden 3.
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Echo Show 15 Camera Replacement, Camera: adım 4, 3 resimden 1. Amazon Echo Show 15 Camera Replacement, Camera: adım 4, 3 resimden 2. Amazon Echo Show 15 Camera Replacement, Camera: adım 4, 3 resimden 3.
    • Remove the small connector from the main device.
    • Disconnect the camera cord from the motherboard.
    • Pull the camera out of the main device.
    • The camera is connected to the main device with adhesive. You will need to use a bit more force to get it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Paysen Hudson
208 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G4
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 390
