Ana içeriğe geç
Amazon Echo Show 15 Microphone Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 15 Microphone Replacement, Back Panel: adım 1, 3 resimden 1. Amazon Echo Show 15 Microphone Replacement, Back Panel: adım 1, 3 resimden 2. Amazon Echo Show 15 Microphone Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Echo Show 15 Microphone Replacement: adım 2, 3 resimden 1. Amazon Echo Show 15 Microphone Replacement: adım 2, 3 resimden 2. Amazon Echo Show 15 Microphone Replacement: adım 2, 3 resimden 3.
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: adım 3, 3 resimden 1. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: adım 3, 3 resimden 2. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: adım 3, 3 resimden 3.
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Echo Show 15 Microphone Replacement, Microphone: adım 4, 2 resimden 1. Amazon Echo Show 15 Microphone Replacement, Microphone: adım 4, 2 resimden 2.
    • Locate the microphone panel on the top right hand corner.
    • Remove the two 3 mm screws with a Torx T3 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Amazon Echo Show 15 Microphone Replacement: adım 5, 2 resimden 1. Amazon Echo Show 15 Microphone Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the microphone.
    • You may use tweezers for this step if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Talara
318 İtibar
3 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G4
3 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great tutorial. One question though, where do you get the new microphone?
Trevor Richardson - Yanıt Paylaş
Hi what is the other wire on the top that displays mic as well ?
Eddy Elias - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 719
