Ana içeriğe geç
Amazon Echo Show 2nd Gen Sound foam Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: adım 1, 3 resimden 1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: adım 1, 3 resimden 2. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: adım 1, 3 resimden 3.
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: adım 2, 3 resimden 1. Amazon Echo Show 2nd Gen Sound foam Replacement: adım 2, 3 resimden 2. Amazon Echo Show 2nd Gen Sound foam Replacement: adım 2, 3 resimden 3.
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,704
