Ana içeriğe geç
Amazon Echo Show 5 Microphone Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 5 Microphone Replacement, Amazon Echo Show 5 Disassembly: adım 1, 3 resimden 1. Amazon Echo Show 5 Microphone Replacement, Amazon Echo Show 5 Disassembly: adım 1, 3 resimden 2. Amazon Echo Show 5 Microphone Replacement, Amazon Echo Show 5 Disassembly: adım 1, 3 resimden 3.
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Echo Show 5 Microphone Replacement: adım 2, 2 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 2, 2 resimden 2.
    • Remove the three screws with a T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Echo Show 5 Microphone Replacement: adım 3, 3 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 3, 3 resimden 2. Amazon Echo Show 5 Microphone Replacement: adım 3, 3 resimden 3.
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Echo Show 5 Microphone Replacement: adım 4, 1 resimden 1.
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
    FixBot'a Sor
    Yorum Ekle
  5. Amazon Echo Show 5 Microphone Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
    FixBot'a Sor
    Yorum Ekle
  6. Amazon Echo Show 5 Microphone Replacement: adım 6, 2 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 6, 2 resimden 2.
    • Disconnect the five ribbon cables connecting to the motherboard.
    • To disconnect the cables, use the tip of a prying tool, or your fingernail, to flip up the small locking flap. Then, you can safely pull the cable out.
    • Be sure to pry up the hinged flap, not the connector socket.
    • There is a white line on the ribbon connectors that indicates the edge of the connection area. To reinstall, insert the connector up to this white line and close the flap. If the white line is clearly visible after closing the flap, it is probably misaligned and needs to be repositioned.
    FixBot'a Sor
    Yorum Ekle
  7. Amazon Echo Show 5 Microphone Replacement: adım 7, 1 resimden 1.
    • Remove the six 4 mm screws that are used to hold down the motherboard using a T6 Security Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Amazon Echo Show 5 Microphone Replacement: adım 8, 2 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard up and out.
    FixBot'a Sor
    Yorum Ekle
  9. Amazon Echo Show 5 Microphone Replacement, Microphone: adım 9, 3 resimden 1. Amazon Echo Show 5 Microphone Replacement, Microphone: adım 9, 3 resimden 2. Amazon Echo Show 5 Microphone Replacement, Microphone: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the Philips #000 Screwdriver to remove two 4mm screws that hold down the metal bracket.
    • Use tweezers to remove the metal bracket by lifting it up and towards yourself.
    FixBot'a Sor
    Yorum Ekle
  10. Amazon Echo Show 5 Microphone Replacement: adım 10, 3 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 10, 3 resimden 2. Amazon Echo Show 5 Microphone Replacement: adım 10, 3 resimden 3.
    • Use a spudger or your fingernail to remove the ribbon connector which connects the speaker housing board to the microphone board.
    • Ribbon connectors are very fragile, do not bend kink or bend them excessively. This will result in damage to the device.
    • There is a white line on the ribbon connector. During reassembly ensure that the white connector is inserted up to the white line and that the white line is not misaligned with the ribbon connector.
    FixBot'a Sor
    Yorum Ekle
  11. Amazon Echo Show 5 Microphone Replacement: adım 11, 3 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 11, 3 resimden 2. Amazon Echo Show 5 Microphone Replacement: adım 11, 3 resimden 3.
    • Use the Philips #000 Screwdriver to remove the four 4 mm screws that attach the microphone board to the case.
    FixBot'a Sor
    Yorum Ekle
  12. Amazon Echo Show 5 Microphone Replacement: adım 12, 2 resimden 1. Amazon Echo Show 5 Microphone Replacement: adım 12, 2 resimden 2.
    • Use a tweezer to remove the microphone board from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Sardinha
247 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Petersen Fall 2022 UMass Dartmouth, Team 2-4, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 90
Her zaman: 2,693
