Giriş
The motherboard is the most important part of your Echo Show, as it is responsible for all operations the device does. If you believe that your Echo Show may have a faulty motherboard (e.g. no power, graphical glitches), then follow this guide to replace it.
Neye ihtiyacın var
Use a prying tool to remove the rubber foot at the bottom.
Use an opening pick to remove the screw cover.
Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
Use an opening tool to flip up the black ZIF locking flap that secure the four ribbon cables.
Bir başkası bu kılavuzu tamamladı.
