Ana içeriğe geç
Amazon Echo Show 8 3rd Gen Power Board Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: adım 1, 3 resimden 1. Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: adım 1, 3 resimden 2. Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: adım 1, 3 resimden 3.
    • Use a prying tool to remove the rubber foot at the bottom.
    • It is secured with adhesive and will lift off with some gentle prying.
    • Use an opening pick to remove the screw cover.
  2. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 2, 2 resimden 1. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 2, 2 resimden 2.
    • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
  3. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 3, 2 resimden 1. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 3, 2 resimden 2.
    • Insert a jimmy in the gap between the display and chassis.
    • Pry around the perimeter until the back case releases.
    • Be careful as to not damage the ribbon cable on the top left area of the screen.
    • Remove the back case.
  4. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 4, 3 resimden 1. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 4, 3 resimden 2. Amazon Echo Show 8 3rd Gen Power Board Replacement: adım 4, 3 resimden 3.
    • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
    • Carefully lift the board without straining the ribbon cable.
    • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
    • Disconnect the ribbon cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 51
