Ana içeriğe geç
Amazon Echo Studio Motherboard Replacement
Neye ihtiyacın var
  1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: adım 1, 3 resimden 1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: adım 1, 3 resimden 2. Amazon Echo Studio Motherboard Replacement, Power Supply Board: adım 1, 3 resimden 3.
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Echo Studio Motherboard Replacement: adım 2, 3 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 2, 3 resimden 2. Amazon Echo Studio Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Echo Studio Motherboard Replacement: adım 3, 3 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 3, 3 resimden 2. Amazon Echo Studio Motherboard Replacement: adım 3, 3 resimden 3.
    • Before fully removing the base, remove the three attached connectors.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Echo Studio Motherboard Replacement: adım 4, 2 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 4, 2 resimden 2.
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
    FixBot'a Sor
    Yorum Ekle
  5. Amazon Echo Studio Motherboard Replacement, Subwoofer: adım 5, 1 resimden 1.
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
    FixBot'a Sor
    Yorum Ekle
  6. Amazon Echo Studio Motherboard Replacement: adım 6, 3 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 6, 3 resimden 2. Amazon Echo Studio Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
    FixBot'a Sor
    Yorum Ekle
  7. Amazon Echo Studio Motherboard Replacement: adım 7, 2 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 7, 2 resimden 2.
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
    FixBot'a Sor
    Yorum Ekle
  8. Amazon Echo Studio Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Amazon Echo Studio Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the thirteen 9 mm Phillips #00 screws.
    • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
    FixBot'a Sor
    Yorum Ekle
  9. Amazon Echo Studio Motherboard Replacement: adım 9, 1 resimden 1.
    • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
    • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
    FixBot'a Sor
    Yorum Ekle
  10. Amazon Echo Studio Motherboard Replacement: adım 10, 3 resimden 1. Amazon Echo Studio Motherboard Replacement: adım 10, 3 resimden 2. Amazon Echo Studio Motherboard Replacement: adım 10, 3 resimden 3.
    • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Amazon Echo Studio Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard from the device by pulling it out.
    • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Colin Nicoll
109 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G6
4 Üyeler
7 adet Kılavuz yazıldı
6Kılavuz Yorumları
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - Yanıt Paylaş
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - Yanıt Paylaş
i also would like to know. mine stuck with cyan circle
Алексей - Yanıt Paylaş
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - Yanıt Paylaş
hi is there a place to buy this motherboard?
Bede Bede - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 61
Her zaman: 2,308
