Giriş
The Echo Studio motherboard is located deep in the device, and other components must be extracted to reach the motherboard. Causes of a faulty motherboard include the device being dropped from a high distance, repeated button use, etc... If there are signs of a faulty motherboard, such as not carrying out proper functions, access the motherboard with this guide.
Neye ihtiyacın var
Flip the device upside down.
Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
Remove the two screws located across from each other on the outside of the plastic ring shown.
Remove the plastic outer ring that hugs the inside of the edges of the device.
On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
6Kılavuz Yorumları
where can I buy a motherboard replacement ?
