Giriş
This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
Neye ihtiyacın var
Peel off the rubber footing from the bottom of the Echo.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
3Kılavuz Yorumları
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
