Ana içeriğe geç
Amazon Echo Woofer Replacement
Neye ihtiyacın var
    1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: adım 1, 1 resimden 1.
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Echo Woofer Replacement: adım 2, 3 resimden 1. Amazon Echo Woofer Replacement: adım 2, 3 resimden 2. Amazon Echo Woofer Replacement: adım 2, 3 resimden 3.
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Echo Woofer Replacement: adım 3, 1 resimden 1.
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Echo Woofer Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      FixBot'a Sor
      Yorum Ekle
    5. Amazon Echo Woofer Replacement: adım 5, 2 resimden 1. Amazon Echo Woofer Replacement: adım 5, 2 resimden 2.
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      FixBot'a Sor
      Yorum Ekle
    6. Amazon Echo Woofer Replacement: adım 6, 3 resimden 1. Amazon Echo Woofer Replacement: adım 6, 3 resimden 2. Amazon Echo Woofer Replacement: adım 6, 3 resimden 3.
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Echo Woofer Replacement, Tweeter Assembly: adım 7, 2 resimden 1. Amazon Echo Woofer Replacement, Tweeter Assembly: adım 7, 2 resimden 2.
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Echo Woofer Replacement: adım 8, 1 resimden 1.
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Echo Woofer Replacement: adım 9, 3 resimden 1. Amazon Echo Woofer Replacement: adım 9, 3 resimden 2. Amazon Echo Woofer Replacement: adım 9, 3 resimden 3.
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Echo Woofer Replacement, Woofer: adım 10, 1 resimden 1.
      • Lift the woofer out of the Echo.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Albert
1.169 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G3
4 Üyeler
19 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can you buy a replacement woofer?
adam mierzwa - Yanıt Paylaş
My exact question.
Marty Koenig - Yanıt Paylaş
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 8,679
