Ana içeriğe geç
Amazon Fire Game Controller Outer Shell Replacement
Neye ihtiyacın var
  1. Amazon Fire Game Controller Outer Shell Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
  2. Amazon Fire Game Controller Outer Shell Replacement: adım 2, 1 resimden 1.
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
  3. Amazon Fire Game Controller Outer Shell Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
  4. Amazon Fire Game Controller Outer Shell Replacement: adım 4, 1 resimden 1.
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
  5. Amazon Fire Game Controller Outer Shell Replacement: adım 5, 1 resimden 1.
    • Lift the motherboard out of the controller casing.
  6. Amazon Fire Game Controller Outer Shell Replacement, Outer Shell: adım 6, 1 resimden 1.
    • Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
  7. Amazon Fire Game Controller Outer Shell Replacement: adım 7, 1 resimden 1.
    • Use a JIS #0 screwdriver to unscrew the 5 mm screws from the LED indicator assembly.
  8. Amazon Fire Game Controller Outer Shell Replacement: adım 8, 2 resimden 1. Amazon Fire Game Controller Outer Shell Replacement: adım 8, 2 resimden 2.
    • Slide out the triggers and bumpers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Klopfenstein
37 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Summer 2019 IUPUI, Team S4-G4, Wilson Summer 2019 üyesi
IUPUI-WILSON-SU19S4G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 736
