Ana içeriğe geç
Amazon Fire HD 10 Battery Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 10 Battery Replacement, Screen: adım 1, 3 resimden 1. Amazon Fire HD 10 Battery Replacement, Screen: adım 1, 3 resimden 2. Amazon Fire HD 10 Battery Replacement, Screen: adım 1, 3 resimden 3.
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 10 Battery Replacement: adım 2, 1 resimden 1.
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 10 Battery Replacement: adım 3, 2 resimden 1. Amazon Fire HD 10 Battery Replacement: adım 3, 2 resimden 2.
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 10 Battery Replacement: adım 4, 1 resimden 1.
      • Remove the screen and digitizer from the case completely.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Fire HD 10 Battery Replacement, Battery: adım 5, 3 resimden 1. Amazon Fire HD 10 Battery Replacement, Battery: adım 5, 3 resimden 2. Amazon Fire HD 10 Battery Replacement, Battery: adım 5, 3 resimden 3.
      • Locate the power cable that links the battery to the motherboard.
      • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
      • The third image shows what it should look like with the battery power cable is disconnected.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 10 Battery Replacement: adım 6, 3 resimden 1. Amazon Fire HD 10 Battery Replacement: adım 6, 3 resimden 2. Amazon Fire HD 10 Battery Replacement: adım 6, 3 resimden 3.
      • Begin by locating the double sided pull tape locations.
      • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
      • Pull the black soft tabs to release the tape's adhesion.
      • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
      • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 10 Battery Replacement: adım 7, 3 resimden 1. Amazon Fire HD 10 Battery Replacement: adım 7, 3 resimden 2. Amazon Fire HD 10 Battery Replacement: adım 7, 3 resimden 3.
      • Make sure all the adhesive is removed before trying to lift the battery from the case.
      • After the battery is totally free of any adhesion, simply lift the battery from the case.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 10 Battery Replacement: adım 8, 3 resimden 1. Amazon Fire HD 10 Battery Replacement: adım 8, 3 resimden 2. Amazon Fire HD 10 Battery Replacement: adım 8, 3 resimden 3.
      • Inspect battery for any leakage.
      • Please follow all U.S. regulations and laws when disposing or recycling the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jaie Hillery
1.774 İtibar
10 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G6
3 Üyeler
72 adet Kılavuz yazıldı
9Kılavuz Yorumları
why is there so much empty space next to the battery?
echow2001 - Yanıt Paylaş
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue - Yanıt Paylaş
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - Yanıt Paylaş
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 58
Son 30 gün: 202
Her zaman: 52,534
