Ana içeriğe geç
Amazon Fire HD 10 Front Facing Camera Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: adım 1, 3 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: adım 1, 3 resimden 2. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: adım 1, 3 resimden 3.
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 10 Front Facing Camera Replacement: adım 2, 1 resimden 1.
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 10 Front Facing Camera Replacement: adım 3, 2 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement: adım 3, 2 resimden 2.
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 10 Front Facing Camera Replacement: adım 4, 1 resimden 1.
      • Remove the screen and digitizer from the case completely.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 2. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 3.
      • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
      • Make sure you place the screws in a safe location nearby.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 10 Front Facing Camera Replacement: adım 6, 2 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement: adım 6, 2 resimden 2.
      • Lift the black plastic cover once the screws are removed.
      • Place aside for later reassembly.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 10 Front Facing Camera Replacement: adım 7, 2 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement: adım 7, 2 resimden 2.
      • Detach the connector using a plastic opening tool or spudger.
      • The camera is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 10 Front Facing Camera Replacement: adım 8, 2 resimden 1. Amazon Fire HD 10 Front Facing Camera Replacement: adım 8, 2 resimden 2.
      • Grip the camera and lift up to detach the ZIF connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jaie Hillery
1.774 İtibar
10 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G6
3 Üyeler
72 adet Kılavuz yazıldı
1Rehber Yorum
Can this camera module be upgraded with a better version?
Jimmy Kee - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 1,648
