Giriş
You will need to use the screen replacement guide as a prerequisite.
Neye ihtiyacın var
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Bir başkası bu kılavuzu tamamladı.
The right side with the power switch on top?
Sonny Shear - Yanıt
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Yanıt
