Ana içeriğe geç
Amazon Fire HD 10 Screen Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 10 Screen Replacement, Screen: adım 1, 3 resimden 1. Amazon Fire HD 10 Screen Replacement, Screen: adım 1, 3 resimden 2. Amazon Fire HD 10 Screen Replacement, Screen: adım 1, 3 resimden 3.
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 10 Screen Replacement: adım 2, 1 resimden 1.
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 10 Screen Replacement: adım 3, 2 resimden 1. Amazon Fire HD 10 Screen Replacement: adım 3, 2 resimden 2.
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 10 Screen Replacement: adım 4, 1 resimden 1.
      • Remove the screen and digitizer from the case completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Jaie Hillery
1.774 İtibar
10 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G6
3 Üyeler
72 adet Kılavuz yazıldı
17Kılavuz Yorumları
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Yanıt Paylaş
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland - Yanıt Paylaş
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Yanıt Paylaş
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Yanıt Paylaş
What is needed to attach the screen back to the case?
Jimmy Lee - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 144
Her zaman: 40,266
