Ana içeriğe geç
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
Neye ihtiyacın var
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: adım 1, 3 resimden 1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: adım 1, 3 resimden 2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: adım 1, 3 resimden 3.
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: adım 2, 1 resimden 1.
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: adım 3, 1 resimden 1.
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: adım 4, 2 resimden 1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: adım 4, 2 resimden 2.
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Sonuç
Omir Rosado
725 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 611
