Ana içeriğe geç
Amazon Fire HD 7 (4th Generation) Speaker
Neye ihtiyacın var
  1. Amazon Fire HD 7 (4th Generation) Speaker, Motherboard: adım 1, 3 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker, Motherboard: adım 1, 3 resimden 2. Amazon Fire HD 7 (4th Generation) Speaker, Motherboard: adım 1, 3 resimden 3.
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation) Speaker: adım 2, 1 resimden 1.
    • Once all clips have been released, remove the back case to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation) Speaker: adım 3, 3 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 3, 3 resimden 2. Amazon Fire HD 7 (4th Generation) Speaker: adım 3, 3 resimden 3.
    • Remove the nine silver screws located around the motherboard with the T5 Torx screwdriver.
  4. Amazon Fire HD 7 (4th Generation) Speaker: adım 4, 3 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 4, 3 resimden 2. Amazon Fire HD 7 (4th Generation) Speaker: adım 4, 3 resimden 3.
    • Remove the six black screws located around the battery and the speaker with the T5 Torx screwdriver.
    • Make your way around the battery and speaker to remove all of them.
  5. Amazon Fire HD 7 (4th Generation) Speaker: adım 5, 3 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 5, 3 resimden 2. Amazon Fire HD 7 (4th Generation) Speaker: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Carefully unplug the three wire connections by placing a plastic spudger under the connections and lifting up.
    • Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
    • Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
  6. Amazon Fire HD 7 (4th Generation) Speaker: adım 6, 2 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 6, 2 resimden 2.
    • Remove the two screws holding the rear camera in place using the T5 Torx screwdriver.
    • Once freed from the screws, gently lift and remove the rear camera.
    • The camera lens is sensitive. Be careful when removing and handling the rear camera.
  7. Amazon Fire HD 7 (4th Generation) Speaker: adım 7, 2 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 7, 2 resimden 2.
    • Now the motherboard is free to be removed.
    • Lift the motherboard up to remove it as shown in the picture.
  8. Amazon Fire HD 7 (4th Generation) Speaker, Speaker: adım 8, 1 resimden 1.
    • Remove the single silver screw with the T5 Torx screwdriver.
  9. Amazon Fire HD 7 (4th Generation) Speaker: adım 9, 1 resimden 1.
    • Remove the two black screws using the T5 Torx screwdriver.
  10. Amazon Fire HD 7 (4th Generation) Speaker: adım 10, 3 resimden 1. Amazon Fire HD 7 (4th Generation) Speaker: adım 10, 3 resimden 2. Amazon Fire HD 7 (4th Generation) Speaker: adım 10, 3 resimden 3.
    • Gently pry the speaker from the device with the iFixit opening tool.
    • If the speaker does not immediately pop out, grab it by the top and slide it out sideways away from the device, while applying a slight upward force.
    • Remove the speaker.
Bitiş Çizgisi
Omir Rosado
725 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,380
