Ana içeriğe geç
Amazon Fire HD 8 12th Gen Camera Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: adım 1, 3 resimden 1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: adım 1, 3 resimden 2. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: adım 1, 3 resimden 3.
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 12th Gen Camera Replacement: adım 2, 2 resimden 1. Amazon Fire HD 8 12th Gen Camera Replacement: adım 2, 2 resimden 2.
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: adım 3, 2 resimden 1. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: adım 3, 2 resimden 2.
      • Using the iFixit opening tool, disconnect the battery from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 12th Gen Camera Replacement: adım 4, 3 resimden 1. Amazon Fire HD 8 12th Gen Camera Replacement: adım 4, 3 resimden 2. Amazon Fire HD 8 12th Gen Camera Replacement: adım 4, 3 resimden 3.
      • Disconnect the camera from the motherboard by unplugging the orange wiring.
      • Heat the area of the back camera up loosening the glue holding it in place.
      • Be careful when using hot tools and removing hot parts.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 8 12th Gen Camera Replacement: adım 5, 3 resimden 1. Amazon Fire HD 8 12th Gen Camera Replacement: adım 5, 3 resimden 2. Amazon Fire HD 8 12th Gen Camera Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jaden Palmer
485 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 411
