Ana içeriğe geç
Amazon Fire HD 8 12th Gen Screen Replacement
Neye ihtiyacın var
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: adım 1, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: adım 1, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement, Buttons: adım 1, 3 resimden 3.
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 2, 2 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 2, 2 resimden 2.
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Battery: adım 3, 2 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement, Battery: adım 3, 2 resimden 2.
      • Using the iFixit opening tool, disconnect the battery from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 4, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 4, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 4, 3 resimden 3.
      • Slowly and gently, pull and remove the 3 adhesives under the old battery.
      • Remove all 3 by pulling the adhesive, signified by a black flap with white adhesive. You will know it is removed when the adhesive has come out from under the battery and you are now able to move the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 8 12th Gen Screen Replacement: adım 5, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 5, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 5, 3 resimden 3.
      • Remove the old battery from the device using the opening tool.
      • If necessary, clean under your old battery and then insert the new battery with new adhesive to ensure the battery stays in place.
      FixBot'a Sor
      Yorum Ekle
    1. Amazon Fire HD 8 12th Gen Screen Replacement, Screen: adım 6, 2 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement, Screen: adım 6, 2 resimden 2.
      • Start off by heating the edges of the screen to melt the adhesive.
      • Insert the opening picks between the screen and device.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 7, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 7, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 7, 3 resimden 3.
      • Slide the opening pick in between the screen and device, prying it just above the device.
      • Place the suction on the screen
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire HD 8 12th Gen Screen Replacement: adım 8, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 8, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 8, 3 resimden 3.
      • Gently pull the screen off using the suction and opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire HD 8 12th Gen Screen Replacement: adım 9, 3 resimden 1. Amazon Fire HD 8 12th Gen Screen Replacement: adım 9, 3 resimden 2. Amazon Fire HD 8 12th Gen Screen Replacement: adım 9, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Heat up the little black square with yellow orange tape around it on the back of the device, atop the motherboard.
      • Once heated, remove the little black square using tweezers. Unhooking the screen from the screen.
      • Pulling the suction cup, fully remove the screen from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Rama Sura
454 İtibar
3 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Where can i buy a replacement screen?
Imfenway - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 54
Son 30 gün: 184
Her zaman: 4,967
