Ana içeriğe geç
Amazon Fire HD 8 Front Camera Replacement
Neye ihtiyacın var
  1. Amazon Fire HD 8 Front Camera Replacement, Screen: adım 1, 2 resimden 1. Amazon Fire HD 8 Front Camera Replacement, Screen: adım 1, 2 resimden 2.
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Front Camera Replacement: adım 2, 1 resimden 1.
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Front Camera Replacement: adım 3, 3 resimden 1. Amazon Fire HD 8 Front Camera Replacement: adım 3, 3 resimden 2. Amazon Fire HD 8 Front Camera Replacement: adım 3, 3 resimden 3.
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Front Camera Replacement: adım 4, 3 resimden 1. Amazon Fire HD 8 Front Camera Replacement: adım 4, 3 resimden 2. Amazon Fire HD 8 Front Camera Replacement: adım 4, 3 resimden 3.
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Front Camera Replacement, Front Camera: adım 5, 3 resimden 1. Amazon Fire HD 8 Front Camera Replacement, Front Camera: adım 5, 3 resimden 2. Amazon Fire HD 8 Front Camera Replacement, Front Camera: adım 5, 3 resimden 3.
    • Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
    • The gasket may pop out, but it can easily be put back in.
  6. Amazon Fire HD 8 Front Camera Replacement: adım 6, 2 resimden 1. Amazon Fire HD 8 Front Camera Replacement: adım 6, 2 resimden 2.
    • Using tweezers, gently remove the white tape with the QR code.
    • Fold the camera back and use tweezers to gently remove the orange tab.
Sonuç
Dan Shimkus
1.184 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G3
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 17
Her zaman: 1,775
