Ana içeriğe geç
Amazon Fire HD 8 Plus 12th Gen Battery Replacement
Neye ihtiyacın var
  1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: adım 1, 2 resimden 1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: adım 1, 2 resimden 2.
    • Unplug the charger, power down the device, and remove the SD card before beginning.
    • Insert an opening pick into the seam between the rear case and the screen assembly.
    • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
    • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
    • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
  2. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: adım 2, 1 resimden 1.
    • Remove the rear case.
  3. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: adım 3, 1 resimden 1.
    • Use an opening tool to lift the battery connector until it disconnects.
  4. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
    • The adhesives are marked with a black flap with a white adhesive. You will know it has been successfully removed when you can move the battery around.
  5. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: adım 5, 3 resimden 1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: adım 5, 3 resimden 2. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: adım 5, 3 resimden 3.
    • Gently pry around the entire perimeter of the battery with an opening tool until the adhesive releases.
    • Remove the battery.
    • Take care not to bend or puncture the battery while prying the battery.
    • Clean under the old battery and insert a new battery with adhesive to ensure the battery stays in place.
Sonuç
To reassemble your device, follow these instructions in reverse order. Make sure you have a applied a adhesive for the new battery to make sure it stays in place.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 72
