Giriş
If your kindle fire HD 8 12th generation is experiencing audio issues or getting stuck on the amazon logo screen upon startup, it may be caused by a hardware issue which can be fixed by replacing the motherboard
Neye ihtiyacın var
Insert an opening pick into the seam between the rear case and the screen assembly.
Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
Use an opening tool to lift the battery connector until it disconnects.
Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
