Giriş
If your Kindle Fire HD 8 12th gen is having issues charging, but you know your battery is healthy, try using another cable. If no cable works then this may be caused by a faulty USB port. To replace the USB port, follow these steps below.
Neye ihtiyacın var
Insert an opening pick into the seam between the rear case and the screen assembly.
Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
Use an opening tool to lift the battery connector until it disconnects.
Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
Desolder the speaker motherboard connections.
Lift the speaker up and out of the chassis.
