Ana içeriğe geç
Amazon Fire Phone Battery Replacement
Neye ihtiyacın var
    1. Amazon Fire Phone Battery Replacement, Tape the screen: adım 1, 1 resimden 1.
      • If the display is damaged, use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 1. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 3.
      • Power off your phone.
      • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Fire Phone Battery Replacement: adım 3, 3 resimden 1. Amazon Fire Phone Battery Replacement: adım 3, 3 resimden 2. Amazon Fire Phone Battery Replacement: adım 3, 3 resimden 3.
      • Press the small suction cup just above the home button.
      • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Fire Phone Battery Replacement, Remove Bracket: adım 4, 1 resimden 1.
      • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
      • Remove the silver bracket that was held into place by the three screws just removed.
      FixBot'a Sor
      Yorum Ekle
    5. Amazon Fire Phone Battery Replacement, Disconnect Battery: adım 5, 1 resimden 1.
      • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Lissandra Ilcyn
889 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G7
5 Üyeler
35 adet Kılavuz yazıldı
14Kılavuz Yorumları
Tolle Anleitung DANKE!!
Leo Henn - Yanıt Paylaş
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - Yanıt Paylaş
How to bay amazone fire fone battry in pakistan
Manzoor Khan - Yanıt Paylaş
where can i get fire phone battery in india
Shiva Sai - Yanıt Paylaş
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 81
Her zaman: 14,478
