Ana içeriğe geç
Amazon Fire Phone Headphone Jack Replacement
Neye ihtiyacın var
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: adım 2, 3 resimden 1. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: adım 2, 3 resimden 2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: adım 2, 3 resimden 3.
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: adım 3, 3 resimden 1. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: adım 3, 3 resimden 2. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: adım 3, 3 resimden 3.
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: adım 4, 3 resimden 1. Amazon Fire Phone Headphone Jack Replacement: adım 4, 3 resimden 2. Amazon Fire Phone Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Savannah Moen
237 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G7
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,870
