Ana içeriğe geç
Amazon Fire Phone Micro-USB Port Replacement
Neye ihtiyacın var
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: adım 1, 1 resimden 1.
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 1. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 3.
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: adım 3, 3 resimden 1. Amazon Fire Phone Micro-USB Port Replacement: adım 3, 3 resimden 2. Amazon Fire Phone Micro-USB Port Replacement: adım 3, 3 resimden 3.
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: adım 4, 1 resimden 1.
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: adım 5, 1 resimden 1.
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: adım 6, 2 resimden 1. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: adım 6, 2 resimden 2.
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: adım 7, 3 resimden 1. Amazon Fire Phone Micro-USB Port Replacement: adım 7, 3 resimden 2. Amazon Fire Phone Micro-USB Port Replacement: adım 7, 3 resimden 3.
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: adım 8, 1 resimden 1.
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: adım 9, 3 resimden 1. Amazon Fire Phone Micro-USB Port Replacement: adım 9, 3 resimden 2. Amazon Fire Phone Micro-USB Port Replacement: adım 9, 3 resimden 3.
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: adım 10, 2 resimden 1. Amazon Fire Phone Micro-USB Port Replacement: adım 10, 2 resimden 2.
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: adım 11, 1 resimden 1.
    • Lift off bottom plastic piece with flat antenna cables
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kent Kawahara
110 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G7
5 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 2,681
