Ana içeriğe geç
Amazon Fire Phone Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Amazon Fire Phone Rear Facing Camera Replacement, Tape the screen: adım 1, 1 resimden 1.
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Rear Facing Camera Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement, Power off, remove SIM card, remove screws: adım 2, 3 resimden 3.
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Rear Facing Camera Replacement: adım 3, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement: adım 3, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement: adım 3, 3 resimden 3.
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Rear Facing Camera Replacement, Remove Bracket: adım 4, 1 resimden 1.
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Rear Facing Camera Replacement, Disconnect Battery: adım 5, 1 resimden 1.
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 3 resimden 3.
    • Unscrew the one 1mm standoff screws holding the bracket in place along the top of the phone.
    • Carefully slide the bracket out of the tap and then maneuver the bracket off slowly.
  7. Amazon Fire Phone Rear Facing Camera Replacement: adım 7, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement: adım 7, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement: adım 7, 3 resimden 3.
    • Disconnect the 9 cables along the top and right side of motherboard using a spudger.
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head.
    • Disconnect the cable in order to expose the 5 screws along the right hand side of the motherboard.
  8. Amazon Fire Phone Rear Facing Camera Replacement: adım 8, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement: adım 8, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement: adım 8, 3 resimden 3.
    • Unscrew four 2mm screws to remove the motherboard.
  9. Amazon Fire Phone Rear Facing Camera Replacement: adım 9, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement: adım 9, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement: adım 9, 3 resimden 3.
    • Unscrew the remaining 2 mm screw to remove the motherboard.
    • Carefully lift up the motherboard and use the spudger to pry the camera from the camera holder.
    • Lift off the bottom plastic piece with flat antenna cables.
  10. Amazon Fire Phone Rear Facing Camera Replacement: adım 10, 3 resimden 1. Amazon Fire Phone Rear Facing Camera Replacement: adım 10, 3 resimden 2. Amazon Fire Phone Rear Facing Camera Replacement: adım 10, 3 resimden 3.
    • Flip the motherboard over.
    • Using a philips head screwdriver to remove the remaining 1mm screw holding the bracket that is protecting the camera ribbon cable.
    • Remove the ribbon cable and rear facing camera carefully.
Sonuç
Grayson Starr
113 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G7
5 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Hey you're information are real usual, but replacement for the back glass would be nice as well. I've got mine damaged completely.
Thanks
mystic mac - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,543
