Giriş
Use this guide to replace the rear facing camera located on the back panel of the phone.
Neye ihtiyacın var
Power off your phone.
Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
Press the small suction cup just above the home button.
While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
Remove the silver bracket that was held into place by the three screws just removed.
https://www.youtube.com/watch?v=4U5oMcXD...
A lot easier way to replace it.
I kind of like the way the battery just “disappears” between step 5 and 6; mine was glued in with a REALLY good quality adhesive tape that took some chiseling to get free; happily, the battery didn’t explode, hopefully it will still work.
Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
Single hardest step, removing this battery takes both time and the jaws of life, it has an adhesive strip that will nearly RIP the battery or motherboard of the phone part, just keep careful while your at it, both mine and my wifes survived the tearing of this battery out, iv never been so sure I was breaking something while removing the battery but they went back together very easily once the devil adhesive let the battery go. This battery the the differential between a 1star difficulty and the 5star difficulty.
Unscrew the one 1mm standoff screws holding the bracket in place along the top of the phone.
Carefully slide the bracket out of the tap and then maneuver the bracket off slowly.
Bir Yorum
Hey you're information are real usual, but replacement for the back glass would be nice as well. I've got mine damaged completely.
Thanks
