Ana içeriğe geç
Amazon Fire TV Cube Motherboard Replacement
Neye ihtiyacın var
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: adım 1, 3 resimden 1. Amazon Fire TV Cube Motherboard Replacement, Speaker: adım 1, 3 resimden 2. Amazon Fire TV Cube Motherboard Replacement, Speaker: adım 1, 3 resimden 3.
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: adım 2, 3 resimden 1. Amazon Fire TV Cube Motherboard Replacement: adım 2, 3 resimden 2. Amazon Fire TV Cube Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: adım 4, 2 resimden 1. Amazon Fire TV Cube Motherboard Replacement: adım 4, 2 resimden 2.
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Amazon Fire TV Cube Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: adım 6, 2 resimden 1. Amazon Fire TV Cube Motherboard Replacement: adım 6, 2 resimden 2.
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: adım 7, 2 resimden 1. Amazon Fire TV Cube Motherboard Replacement: adım 7, 2 resimden 2.
    • Gently pry the motherboard up and off.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
where do you buy the mother board ?
Sam Handa - Yanıt
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 1,661
