Ana içeriğe geç
Amazon Fire TV Cube Speaker Replacement
Neye ihtiyacın var
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: adım 1, 3 resimden 1. Amazon Fire TV Cube Speaker Replacement, Speaker: adım 1, 3 resimden 2. Amazon Fire TV Cube Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: adım 2, 3 resimden 1. Amazon Fire TV Cube Speaker Replacement: adım 2, 3 resimden 2. Amazon Fire TV Cube Speaker Replacement: adım 2, 3 resimden 3.
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: adım 3, 1 resimden 1.
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: adım 4, 2 resimden 1. Amazon Fire TV Cube Speaker Replacement: adım 4, 2 resimden 2.
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 3,245
