Giriş
If your remote control of the Amazon Fire TV over and over again does not work properly even though the batteries are okay or even new, this repair guide may help you to finally fix the problem.
Root cause could be, that the batteries get stuck on the sides in the battery compartment which leads to a electrical loose contact.
Neye ihtiyacın var
Place the remote control with the battery cover facing up. Pull the tap with your fingernail and flip up the battery cover.
Remove the battery cover.
Before this repair is performed, it has to be checked, if the failure described in this repair guide exists. Check, if the batteries are not empty (in doubt please use new batteries).
Strongly press both batteries to the top of the remote control with a screwdriver (or your fingernails). See arrows in the image.
Wait 10-15 seconds in order to let the remote control reconnect with the Amazon Fire TV.
Check if the remote control now works properly with the Amazon Fire TV. Do not handle the remote control jerkily but very careful and pay attention that the batteries do not fall out.
If the remote control now works properly, continue with this repair guide. If not, stop the repair guide because there might be another root cause of the malfunction.
First pull out the front battery by lifting it, then pull out the second battery.
The next step explains how to fix the problem.
Set the cutter knife carefully to the red bordered part of the rubber battery-fixing.
Lead the cutter knife carefully along the longitudinal direction of the remote control and cut off only the red bordered part of the rubber battery-fixing. See picture.
Put in the batteries in the correct direction (see schematic illustration on the ground of the battery compartment).
Put in and close the battery cover.
Check the function of the remote control. If it does not work, see the note in step 5.
You're done!
I hope that this repair guide was also helpful for you to fix the problem.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
PMB dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2Kılavuz Yorumları
the prong inside my battery compartment is stuck inside they moved fine when changing batteries
My Amazon remote in the UK has a different design. Do you have instructions for this version?
