Ana içeriğe geç
Amazon Fire TV Remote Control Button Panel Replacement
Neye ihtiyacın var
  1. Amazon Fire TV Remote Control Button Panel Replacement, Batteries: adım 1, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement, Batteries: adım 1, 2 resimden 2.
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Fire TV Remote Control Button Panel Replacement: adım 2, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement: adım 2, 2 resimden 2.
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Motherboard: adım 3, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Motherboard: adım 3, 2 resimden 2.
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Fire TV Remote Control Button Panel Replacement: adım 4, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement: adım 4, 2 resimden 2.
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
    FixBot'a Sor
    Yorum Ekle
  5. Amazon Fire TV Remote Control Button Panel Replacement: adım 5, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
    FixBot'a Sor
    Yorum Ekle
  6. Amazon Fire TV Remote Control Button Panel Replacement: adım 6, 1 resimden 1.
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  7. Amazon Fire TV Remote Control Button Panel Replacement: adım 7, 1 resimden 1.
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Button Panel: adım 8, 2 resimden 1. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Button Panel: adım 8, 2 resimden 2.
    • Locate the black plastic tab at the top end of the button panel, grab it with your fingers and pull back to separate the button panel from the remote control's case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Alejandro Franco Ceron
781 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-3, Wollert Fall 2015 USF Tampa, Team 16-3, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G3
4 Üyeler
16 adet Kılavuz yazıldı
3Kılavuz Yorumları
The guide is wrong on step 7, there are 2 more hidden screws behind the plastic curved cover on top. If you get those out, you don't have to apply force to open. With step 7 you brake the metal nuts out of their place.
Raul - Yanıt Paylaş
I’m also not quite convinced about step 5 - the metal nuts are also broken out there, and I can’t seem to get them back in, leaving the case 1mm open round the top.
Romax - Yanıt Paylaş
I too popped it open with force and found the 2 nuts pulled out of their sockets. I was able to remove the screws from the case, then re-insert the screws into the nuts and punch them (hard) back into the little socket holes. They stuck fast, and didn’t spin when I reassembled the remote.
Ronald Goers - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 40
Son 30 gün: 162
Her zaman: 29,457
