Ana içeriğe geç
Amazon Kindle 8 Power Button Replacement
Neye ihtiyacın var
  1. Amazon Kindle 8 Power Button Replacement, Front Cover: adım 1, 2 resimden 1. Amazon Kindle 8 Power Button Replacement, Front Cover: adım 1, 2 resimden 2.
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Power Button Replacement: adım 2, 2 resimden 1. Amazon Kindle 8 Power Button Replacement: adım 2, 2 resimden 2.
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Power Button Replacement, Motherboard: adım 3, 2 resimden 1. Amazon Kindle 8 Power Button Replacement, Motherboard: adım 3, 2 resimden 2.
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Power Button Replacement: adım 4, 2 resimden 1. Amazon Kindle 8 Power Button Replacement: adım 4, 2 resimden 2.
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Power Button Replacement, Power Button: adım 5, 2 resimden 1. Amazon Kindle 8 Power Button Replacement, Power Button: adım 5, 2 resimden 2.
    • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
    • Remove the power button.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
432 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 64
Her zaman: 537
