Ana içeriğe geç
Amazon Kindle DX LCD Replacement
Neye ihtiyacın var
    1. Amazon Kindle DX LCD Replacement, Liquid Crystal Display (LCD): adım 1, 1 resimden 1.
      • Take your Kindle and place it screen side down in order to open it from the back. Use the opening tool from the ifixit tool kit and insert it between the metal casing and plastic top piece.
      FixBot'a Sor
      Yorum Ekle
    2. Amazon Kindle DX LCD Replacement: adım 2, 1 resimden 1.
      • Once enough pressure is applied the small piece will pop open.
      FixBot'a Sor
      Yorum Ekle
    3. Amazon Kindle DX LCD Replacement: adım 3, 1 resimden 1.
      • Remove the plastic piece.
      FixBot'a Sor
      Yorum Ekle
    4. Amazon Kindle DX LCD Replacement: adım 4, 2 resimden 1. Amazon Kindle DX LCD Replacement: adım 4, 2 resimden 2.
      • Once the small plastic piece is removed you will need to locate two 40mm screws on both corners of the remaining casing. Use the PH000 Philips Head Screwdriver from the tool kit to remove both screws.
      FixBot'a Sor
      Yorum Ekle
    5. Amazon Kindle DX LCD Replacement: adım 5, 1 resimden 1.
      • Use the opening tool again to take the off the bigger metal piece.
      FixBot'a Sor
      Yorum Ekle
    6. Amazon Kindle DX LCD Replacement: adım 6, 1 resimden 1.
      • Once the piece removed, locate the battery.
      FixBot'a Sor
      Yorum Ekle
    7. Amazon Kindle DX LCD Replacement: adım 7, 2 resimden 1. Amazon Kindle DX LCD Replacement: adım 7, 2 resimden 2.
      • Locate the two 30mm screws securing the battery on the bottom of the Kindle DX. Use the PH00 Philips head screw driver from the tool kit to remove both screws.
      FixBot'a Sor
      Yorum Ekle
    8. Amazon Kindle DX LCD Replacement: adım 8, 2 resimden 1. Amazon Kindle DX LCD Replacement: adım 8, 2 resimden 2.
      • Take the battery off once the screws have been removed.
      FixBot'a Sor
      Yorum Ekle
    9. Amazon Kindle DX LCD Replacement: adım 9, 2 resimden 1. Amazon Kindle DX LCD Replacement: adım 9, 2 resimden 2.
      • Unscrew the 30 mm screws using a Phillips #000 screwdriver as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    10. Amazon Kindle DX LCD Replacement: adım 10, 2 resimden 1. Amazon Kindle DX LCD Replacement: adım 10, 2 resimden 2.
      • Unscrew the 30 mm screws using a Phillips #000 screwdriver as demonstrated in the picture.
      FixBot'a Sor
      Yorum Ekle
    11. Amazon Kindle DX LCD Replacement: adım 11, 1 resimden 1.
      • Remove the black case to reveal the mother board.
      FixBot'a Sor
      Yorum Ekle
    12. Amazon Kindle DX LCD Replacement: adım 12, 1 resimden 1.
      • Remove the motherboard from the display assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Lori White
589 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
3Kılavuz Yorumları
Guide is incomplete :(
Robert Rogers - Yanıt Paylaş
I can follow and understand up to step 11.
Steps 12 and 13 loose me, why would one need to remove the metal protection lid / shield? There does not seem to be any screws covered by the lids that need to be removed.
one would need to unclip the screen from the motherboard the lead off board from the wireless card to aerial and unscrew the remaining motherboard screws at least before you could remove the motherboard to access the screen to replace it.
Terry Mummery - Yanıt Paylaş
Guide is useless and should be removed or replaced.
golan.benoni - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 55
Her zaman: 4,439
