Ana içeriğe geç
Amazon Kindle Oasis 8th Gen Charging Port Replacement
Neye ihtiyacın var
  1. Amazon Kindle Oasis 8th Gen Charging Port Replacement, Back Panel: adım 1, 1 resimden 1.
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 2, 3 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 2, 3 resimden 2. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 2, 3 resimden 3.
    • Work your way around the back panel to free all the clips.
    • There are 5 clips on the long and thickest side of the oasis, and none on the others.
  3. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 3, 2 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 3, 2 resimden 2.
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
  4. Amazon Kindle Oasis 8th Gen Charging Port Replacement, Battery: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, lift the orange bridge connector off.
    • Place the tweezers in between the battery and the end of the bridge and lift upwards.
  5. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 5, 2 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 5, 2 resimden 2.
    • Gently wedge the spudger under the battery starting from the left side, and slowly work the spudger around the edge to loosen the battery from the tape. Be careful not to rip the thin foil on the back of the battery.
    • Only use ESD safe tools when working on internal components of your device such as a spudger or opening tool.
    • It is not advised to use a metal spudger, as you could puncture the battery.
  6. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 6, 1 resimden 1.
    • Lift the battery up using a spudger and use your fingers to slowly pull the battery off the adhesive.
  7. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 7, 2 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 7, 2 resimden 2.
    Satın Al
    • Using the tweezers, gently lift the tape off of the Power bridge connector. If a new unit comes with a new piece of tape, remove entirely, if not remove and place one corner lightly face down on a clean surface to be used again.
  8. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 8, 1 resimden 1.
    • Once free of the adhesive and connectors, remove the old battery from the device.
    • Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
    • Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
  9. Amazon Kindle Oasis 8th Gen Charging Port Replacement, Charging Port: adım 10, 3 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement, Charging Port: adım 10, 3 resimden 2. Amazon Kindle Oasis 8th Gen Charging Port Replacement, Charging Port: adım 10, 3 resimden 3.
    • Locate the 2 Phillips screws (labeled PH 0) and remove screws using a screwdriver with a PH0 bit.
  10. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 11, 3 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 11, 3 resimden 2. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 11, 3 resimden 3.
    • Using the metal spudger, tweezers, and your finger tips, gently lift the orange power bridge connector off of the motherboard first and then off of the kindle.
  11. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 12, 2 resimden 1. Amazon Kindle Oasis 8th Gen Charging Port Replacement: adım 12, 2 resimden 2.
    • Use the tweezers to pluck the orange bridge power connector from the Kindle. The charging port and power button is attached to the connector.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mohamed Elzini
416 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G5, Eyestone Fall 2017 USF Tampa, Team S16-G5, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G5
4 Üyeler
16 adet Kılavuz yazıldı
7 Yorum
Where did you source a replacement charging port?
Matthew Gustas - Yanıt
I also need one please, did you ever manage to find one?
Stefan B -
Since I don’t see an answer a year and a half later; I’ll ask the question again. Does anyone know somewhere to order a replacement charge port for this model? The replacement procedure doesn’t seem too difficult but I can’t find the Kindle Oasis part that is inclusive with the ribbon cable anywhere.
William McGinnis - Yanıt
I also am trying to purchase a replacement. Anyone have any success?
Vincent Bryan - Yanıt
Ditto .looking everywhere. Any ideas?
Bobby Turner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 60
Her zaman: 4,238
