Giriş
A defective power button can lead to a lot of problems with your Kindle. The power button of the Kindle turns the Kindle on and off. If defective, turning on your Kindle will become a tedious task. This guide will teach you how to replace the power button for your Kindle.
Neye ihtiyacın var
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Using tweezers, lift the orange bridge connector off.
Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
Locate the 2 Phillips screws (labeled PH 0) and remove screws using a screwdriver with a PH0 bit.
Bir Yorum
Hi. Thank you for making such detailed instructions for replacing the power switch. Where can I get a replacement power button for the Kindle Oasis (8th generation)? I'm sure it's a commodity part, but I don't know which part would be a like-for-like replacement.
