Ana içeriğe geç
Amazon Luna Controller Buttons Replacement
Neye ihtiyacın var
  1. Amazon Luna Controller Buttons Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the controller over so that the back panel is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Amazon Luna Controller Buttons Replacement: adım 2, 3 resimden 1. Amazon Luna Controller Buttons Replacement: adım 2, 3 resimden 2. Amazon Luna Controller Buttons Replacement: adım 2, 3 resimden 3.
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
    FixBot'a Sor
    Yorum Ekle
  3. Amazon Luna Controller Buttons Replacement, Faceplate: adım 3, 1 resimden 1.
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
    FixBot'a Sor
    Yorum Ekle
  4. Amazon Luna Controller Buttons Replacement: adım 4, 1 resimden 1.
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
    FixBot'a Sor
    Yorum Ekle
  5. Amazon Luna Controller Buttons Replacement: adım 5, 2 resimden 1. Amazon Luna Controller Buttons Replacement: adım 5, 2 resimden 2.
    • Once all clips are released, lift the front plate away from the controller.
    FixBot'a Sor
    Yorum Ekle
  6. Amazon Luna Controller Buttons Replacement, Buttons: adım 6, 2 resimden 1. Amazon Luna Controller Buttons Replacement, Buttons: adım 6, 2 resimden 2.
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Amazon Luna Controller Buttons Replacement: adım 7, 2 resimden 1. Amazon Luna Controller Buttons Replacement: adım 7, 2 resimden 2.
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
    FixBot'a Sor
    Yorum Ekle
  8. Amazon Luna Controller Buttons Replacement: adım 8, 3 resimden 1. Amazon Luna Controller Buttons Replacement: adım 8, 3 resimden 2. Amazon Luna Controller Buttons Replacement: adım 8, 3 resimden 3.
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 319
