Ana içeriğe geç
Amazon Luna Controller Shell Replacement
Neye ihtiyacın var
  1. Amazon Luna Controller Shell Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Shell Replacement: adım 2, 3 resimden 1. Amazon Luna Controller Shell Replacement: adım 2, 3 resimden 2. Amazon Luna Controller Shell Replacement: adım 2, 3 resimden 3.
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Shell Replacement, Faceplate: adım 3, 1 resimden 1.
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Shell Replacement: adım 4, 1 resimden 1.
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Shell Replacement: adım 5, 2 resimden 1. Amazon Luna Controller Shell Replacement: adım 5, 2 resimden 2.
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Shell Replacement, Buttons: adım 6, 2 resimden 1. Amazon Luna Controller Shell Replacement, Buttons: adım 6, 2 resimden 2.
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Shell Replacement: adım 7, 2 resimden 1. Amazon Luna Controller Shell Replacement: adım 7, 2 resimden 2.
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Shell Replacement: adım 8, 3 resimden 1. Amazon Luna Controller Shell Replacement: adım 8, 3 resimden 2. Amazon Luna Controller Shell Replacement: adım 8, 3 resimden 3.
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
  9. Amazon Luna Controller Shell Replacement, Joystick Cover: adım 9, 2 resimden 1. Amazon Luna Controller Shell Replacement, Joystick Cover: adım 9, 2 resimden 2.
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
  10. Amazon Luna Controller Shell Replacement, Shell: adım 10, 2 resimden 1. Amazon Luna Controller Shell Replacement, Shell: adım 10, 2 resimden 2.
    • Gently grab the controller's circuitry and hold the bottom shell.
    • Pull the circuitry gently out from the shell.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cade Queen
537 İtibar
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - Yanıt
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 200
