Ana içeriğe geç
AmazonBasics B0050BPWBQ On/Off Switch Replacement
Neye ihtiyacın var
  1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: adım 1, 2 resimden 1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: adım 1, 2 resimden 2.
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: adım 2, 2 resimden 1. AmazonBasics B0050BPWBQ On/Off Switch Replacement: adım 2, 2 resimden 2.
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: adım 3, 1 resimden 1.
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: adım 4, 2 resimden 1. AmazonBasics B0050BPWBQ On/Off Switch Replacement: adım 4, 2 resimden 2.
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: adım 5, 3 resimden 1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: adım 5, 3 resimden 2. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: adım 5, 3 resimden 3.
    • Pull the front panel away from the shredding unit.
    • Locate the black On/Off switch attached to the front panel where the control board was once attached.
    • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
    But, what do I replace the On/Off Switch with? What is the part number of the replacement switch? How much does it cost?
    Mike Greenawalt - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
Natalie Meert
678 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Baechle Spring 2016 IUPUI, Team 2-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G4
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Does anyone know where to buy a replacement switch?
Shawn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 2,522
