Ana içeriğe geç
AmazonBasics B0050BPWBQ Shredding Gears Replacement
Neye ihtiyacın var
  1. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: adım 1, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: adım 1, 2 resimden 2.
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 2, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 2, 2 resimden 2.
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 3, 1 resimden 1.
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 4, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 4, 2 resimden 2.
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: adım 5, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: adım 5, 2 resimden 2.
    • Unit may be greasy so you may want to grab paper towels/rag when completing these next steps.
    • Locate the large white gears on the side of the shredding unit.
    • Remove two 15 mm Phillips #1 screws that hold the motor in place.
  6. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 6, 3 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 6, 3 resimden 2. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 6, 3 resimden 3.
    • Locate the three washers on the metal triangle piece.
    • Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the metal triangle away from the gears.
  7. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 7, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 7, 2 resimden 2.
    • Remove the middle gear from the shredding unit.
    • Remove the top gear that was located under the middle gear.
  8. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 8, 2 resimden 1. AmazonBasics B0050BPWBQ Shredding Gears Replacement: adım 8, 2 resimden 2.
    • Remove the washer on the last gear using two metal spudgers. Again, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the last gear away from the metal shredding unit.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Natalie Meert
678 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Baechle Spring 2016 IUPUI, Team 2-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G4
4 Üyeler
8 adet Kılavuz yazıldı
7Kılavuz Yorumları
Where did you buy the replacement gears?
DIY Security Guy - Yanıt
I agree, where do you get the replacement gears? I’ve looked everywhere!
CSHardware - Yanıt
Taking the shredder apart is easy, finding and procuring the replacement gears is next to impossible…. It would be worth 130 points if you provided information on that.
Paul Williams - Yanıt
I am also looking for parts.
Carl Young - Yanıt
I need the circuit to determine the valué of a resistance that burned
Ximena A. Oyarzún González - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 55
Her zaman: 11,123
