Giriş
When the gears get worn down, the shredder no longer shreds the papers when inserted into the slot. This guide will show how to remove the gears in order to replace them. You will run into a lot of grease while replacing these gears so have some toweling on hand.
Neye ihtiyacın var
Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
Locate the large white gears on the side of the shredding unit.
Remove two 15 mm Phillips #1 screws that hold the motor in place.
Locate the three washers on the metal triangle piece.
Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
Pull the metal triangle away from the gears.
Remove the middle gear from the shredding unit.
Remove the top gear that was located under the middle gear.
7 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Where did you buy the replacement gears?
I agree, where do you get the replacement gears? I’ve looked everywhere!
Taking the shredder apart is easy, finding and procuring the replacement gears is next to impossible…. It would be worth 130 points if you provided information on that.
I am also looking for parts.
I need the circuit to determine the valué of a resistance that burned
Also looking for the replacement gears. Anyone find a source? Unable to find the proper gear on the internet but someone must know who makes these gears in China.
Found it on eBay, just search "B0050BPWBQ gear"
