Ana içeriğe geç
AmazonBasics B00Q3KFX8U Drive Gear Replacement
Neye ihtiyacın var
    1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: adım 1, 1 resimden 1.
      • Remove the shredder assembly from the paper scrap bin.
      FixBot'a Sor
      Yorum Ekle
    2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 2, 1 resimden 1.
      • Remove the two 10mm PH1 screws holding the small black panel in place.
      FixBot'a Sor
      Yorum Ekle
    3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 3, 2 resimden 1. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 3, 2 resimden 2.
      • Remove the six 14mm PH1 screws holding the bottom cover in place.
      • Remove the cover by lifting straight upwards.
      • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
      FixBot'a Sor
      Yorum Ekle
    4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 4, 1 resimden 1.
      • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
      • The blades are sharp. Coming into contact with them may result in injury.
      FixBot'a Sor
      Yorum Ekle
    5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 5, 2 resimden 1. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 5, 2 resimden 2.
      • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
      FixBot'a Sor
      Yorum Ekle
    6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 6, 1 resimden 1.
      • Use a metal spudger to pry the bracket from the main shredder assembly.
      • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
      FixBot'a Sor
      Yorum Ekle
    7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 7, 2 resimden 1. AmazonBasics B00Q3KFX8U Drive Gear Replacement: adım 7, 2 resimden 2.
      • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
      FixBot'a Sor
      Yorum Ekle
Sonuç
William Foley
548 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Miles Spring 2016 UMass Dartmouth, Team 1-3, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G3
2 Üyeler
16 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where does one buy these gear parts?
opticdreams - Yanıt Paylaş
Hi, you can buy the gear here: https://www.ebay.com/itm/116169745117
Mr. Master - Yanıt Paylaş
I need big wheel for Bonsaii C220-A and need a duel gear wheel (1.6 inches and 0.5 inches) Apelila Apelila paper shredder
Raju Nivarthi - Yanıt Paylaş
Send me a message on eBay, https://www.ebay.com/usr/krunkz, I will recreate your damaged gears for free if you can mail them to me.
Shredder Gears - Yanıt Paylaş
I would not buy the gears from that link on ebay. I paid 10 dollars for 2 3D printed gears. Both stripped almost immediately. I applied new grease and do not think it was my error, but rather poor quality gear replacements. Not worth the time or money.
acoest - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 55
Her zaman: 2,316
