Ana içeriğe geç
AmazonBasics BTV1 Battery Replacement
Neye ihtiyacın var
    1. AmazonBasics BTV1 Battery Replacement, Battery: adım 1, 2 resimden 1. AmazonBasics BTV1 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      FixBot'a Sor
      Yorum Ekle
    2. AmazonBasics BTV1 Battery Replacement: adım 2, 2 resimden 1. AmazonBasics BTV1 Battery Replacement: adım 2, 2 resimden 2.
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      FixBot'a Sor
      Yorum Ekle
    3. AmazonBasics BTV1 Battery Replacement: adım 3, 2 resimden 1. AmazonBasics BTV1 Battery Replacement: adım 3, 2 resimden 2.
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      FixBot'a Sor
      Yorum Ekle
    4. AmazonBasics BTV1 Battery Replacement: adım 4, 2 resimden 1. AmazonBasics BTV1 Battery Replacement: adım 4, 2 resimden 2.
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. AmazonBasics BTV1 Battery Replacement: adım 5, 2 resimden 1. AmazonBasics BTV1 Battery Replacement: adım 5, 2 resimden 2.
      • Lift the motherboard off the face plate, exposing the battery.
      • Lift the battery out of its housing.
      • Use caution when using tools around the battery; batteries can be dangerous if punctured.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Chris Shannon
1.039 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G2
3 Üyeler
10 adet Kılavuz yazıldı
8Kılavuz Yorumları
donde consigo la bateria?
bnet_d72 - Yanıt Paylaş
Nice job, Chris! Thank you.
David Printz - Yanıt Paylaş
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Yanıt Paylaş
Need information on where to get a replacement battery!
dan - Yanıt Paylaş
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 3,784
