Ana içeriğe geç
AmazonBasics BTV1 Speaker Replacement
Neye ihtiyacın var
  1. AmazonBasics BTV1 Speaker Replacement, Speaker: adım 1, 2 resimden 1. AmazonBasics BTV1 Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Speaker Replacement: adım 2, 2 resimden 1. AmazonBasics BTV1 Speaker Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Speaker Replacement: adım 3, 2 resimden 1. AmazonBasics BTV1 Speaker Replacement: adım 3, 2 resimden 2.
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Speaker Replacement: adım 4, 2 resimden 1. AmazonBasics BTV1 Speaker Replacement: adım 4, 2 resimden 2.
    • Gently pull the two plastic connectors from the motherboard.
    • Lift the front panel of the case and remove the speakers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris Shannon
1.039 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G2
3 Üyeler
Bir Yorum
Where do you get replacement speakers? What kind?
laurieshorter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,955
