Ana içeriğe geç
Ambient Weather WS-1001-Wifi Battery Replacement
Neye ihtiyacın var
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: adım 1, 2 resimden 1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: adım 1, 2 resimden 2.
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: adım 2, 1 resimden 1.
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: adım 3, 2 resimden 1. Ambient Weather WS-1001-Wifi Battery Replacement: adım 3, 2 resimden 2.
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Whitaker
122 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G2
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 782
