Ana içeriğe geç
Ambient Weather WS-1001-Wifi LCD Screen Replacement
Neye ihtiyacın var
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: adım 2, 1 resimden 1.
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: adım 4, 2 resimden 1. Ambient Weather WS-1001-Wifi LCD Screen Replacement: adım 4, 2 resimden 2.
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Sonuç
Jeremiah Miskimen
107 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G2
4 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Yanıt
Exactly right.
j drag -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 364
