Ana içeriğe geç
American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement
Neye ihtiyacın var
  1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the sandpaper disc: adım 1, 1 resimden 1.
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement: adım 2, 1 resimden 1.
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: adım 3, 2 resimden 1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: adım 3, 2 resimden 2.
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
197.111 İtibar
416 adet Kılavuz yazıldı
Bir Yorum
replace all three driver pads
THOMAS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 91
Her zaman: 3,642
